Your door seal just "sits" on the door once the panel is removed. Pop off puddle light and slide behind door panel. Pop off driver's seat memory and disconnect if on drivers side. Pull off armrest pad and take off one or two bolts behind it. Pop off inside handle plastic by using small screwdriver. There are two screws behind it. Pop off of window controls and disconnect. (Again, use small screwdriver to start) I think I got them all. After all the bolts are off. The entire is held on with snap clips. Just pull outward from the door starting at the bottom. Once the panel is all the way off, two cables will be connected. Kinda hard to explain in writing but those pop right off. You have to pivot the cable connection to a certain position, then it slides right out.
