1 - 7 of 7 Posts
:clueless: :clueless: :clueless: :duh: I need some help!
Does anybody here knew where I could reset the ECU and locate the fuel line near the engine.
If possible show me some pics.
Thank you and your response would be greatly appreciated.
ARMADA LE 06
Blizzard
ARMADA LE 06
Blizzard
If the ECU reset is not in the "how to" section of this forum I know it is over at Clubtitan.org. Also over at CT look for topics on the ecofuelsystem, there are a bunch of photos there. If you take off the engine cover the fuel line goes into the fuel rail on the driver side of the engine basically right below the front of the engine cover, it'll have a gray clip over the connector.
Red arrow show fuel line, blue arrow show where it's attach to the fuel rail. (See attached pictures)
ECU Resetting Procedures
Timing is extremely critical. If it is NOT DONE within the specify time, the ECU will not reset and the Check Engine Light (CEL) will continue to remain ON. A stop watch or an analog clock with a second’s needle will be useful.
Operations Procedures
1. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
2. Repeat the following steps (2a and 2b) procedures quickly five times within 5 seconds.
2a. Fully depress the accelerator pedal (HARD).
2b. Fully release the accelerator pedal.
3. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking.
4. Fully release the accelerator pedal (while the CEL is still blinking)
5. Wait about 10 second.
6. Fully depress the accelerator pedal and keep it for more than 10 seconds.
7. Fully release the accelerator pedal (The CEL light will continue to blink).
8. Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
If the CEL light continues to remain ON, repeat the above steps. Timing is EXTREMELY critical to resetting the ECU.
Thanks guys. I did came accross to one of the topics here about resetting the ECU and lead me to ClubTitan. The reason, I've asked is I bought a new EnergyCel and that will require to reset the ECU after installing to the fuel line area.
I will let you guys know how it goes.
Thanks again:bow: :awesome:
Armada LE '06
Altima GXE '01
Xterra XE/SE '02
1 - 7 of 7 Posts
