1 - 8 of 8 Posts
I'm having some issues while driving my Armada. Lights come on and engine speed reduces to about 5 mph even if step on the gas it wont go. Any suggestions.
The warranty expired. Dealer charges an arm and a leg.
Car Scanner ELM OBD2
DTC report
Selected brand: Nissan
VIN: JN8AY2NC8H9501029
============1==============
P2101
Raw code: 2101
ECU: Engine control unit
Status: Confirmed
OBDII: Throttle actuator control (TAC) motor - range/performance problem
============2==============
P0506
Raw code: 0506
Status: Confirmed
OBDII: Idle speed control (ISC) system - rpm lower than expected
Nissan: Idle Control System RPM lower Than Expected
============3==============
P2101
Raw code: 2101
Status: Validated fault present at time of request, Validated fault has been present during this drive cycle
============4==============
P0506
Raw code: 0506
============5==============
P1705(00)
Raw code: 170500
ECU: Transmission control unit[Archive (inactive)]
Status: Confirmed
OBDII: Not in P or N During KOEO / KOER
Nissan: Not in P or N During KOEO / KOER; TP Sensor A/T
============6==============
C1118(00)
Raw code: 511800
ECU: ABS control unit[Archive (inactive)]
Status: Confirmed
============7==============
C1130(00)
Raw code: 513000
Status: Confirmed
============8==============
P1830
Raw code: 1830
ECU: All wheel drive system (AWD/4WD)
Status: Pending fault present, Pending fault present during this driving cycle, Test conditions are met, Validated fault has been present during this drive cycle
OBDII: Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Battery
Nissan: Transmission Transfer Case Counter Clockwise Shift Relay Coil Short Circuit To Battery
============9==============
P1829
Raw code: 1829
OBDII: Transmission Transfer Case Counter Clockwise Shift Relay Coil Open Circuit
Nissan: Transmission Transfer Case Counter Clockwise Shift Relay Coil Open Circuit
These are the codes
DTC report
P2101
Raw code: 2101
Status: Confirmed
P0506
Raw code: 0506
Status: Confirmed
P2101
Raw code: 2101
P0506
Raw code: 0506
P1705(00)
Raw code: 170500
Status: Confirmed
C1118(00)
Raw code: 511800
Status: Confirmed
C1130(00)
Raw code: 513000
Status: Confirmed
P1830
Raw code: 1830
P1829
Raw code: 1829
need more info.
what model year? trim?
did you purchase used?
if used, any maintenance records?
have you had the obd port scanned for any codes? if not this is the first step.
mileage?
2017 SV. Bought through Carvana 3 Years ago but started problems 2 months ago. Used obd2 it said it was the throttle body and abs sensor. Replaced throttle body and abs sensors. Still acting up
are you still getting codes?
were the parts used or new? are they oem or generic/aftermarket?
did you do the repairs?
list the codes you got . even if you are not seeing any after the repairs.
Discussion Starter #5
need more info.
mileage?
DTC report
P2101
Raw code: 2101
Status: Confirmed
P0506
Raw code: 0506
Status: Confirmed
P2101
Raw code: 2101
P0506
Raw code: 0506
P1705(00)
Raw code: 170500
Status: Confirmed
C1118(00)
Raw code: 511800
Status: Confirmed
C1130(00)
Raw code: 513000
Status: Confirmed
P1830
Raw code: 1830
P1829
Raw code: 1829
These are the codes
DTC report
P2101
Raw code: 2101
Status: Confirmed
P0506
Raw code: 0506
Status: Confirmed
P2101
Raw code: 2101
P0506
Raw code: 0506
P1705(00)
Raw code: 170500
Status: Confirmed
C1118(00)
Raw code: 511800
Status: Confirmed
C1130(00)
Raw code: 513000
Status: Confirmed
P1830
Raw code: 1830
P1829
Raw code: 1829
the ECM is seen often in these codes, so that may be your issue. there could be wiring issues so you should check the continuity in the main wiring harness.
You’ll need a full range scan/diagnostic tool or a shop that utilizes one in order to figure out what’s causing these DTCs.
No point in spending money in replacing parts that doesn’t fix the issues.
Also, anytime the throttle plate is manually pushed when cleaning the throttle body or even when the throttle body connector is unplugged, there is a relearn procedure that is necessary.
primov8........exactly right! If you replaced a throttle body and did not have a scan tool capable of relearning the base idle correctly....you have NO Chance of fixing it! The PCM is turning a lot of these systems off due to no control over throttle body. Get the idle learned first, then see what you have left.
1 - 8 of 8 Posts
