Having lurked here for some months I've got a situation I'm hoping you folks can help me with. The tach on my 2006 QX56 is very erratic. When I start the engine it may act normal, go down (counterclockwise) instead of up, go to 7,000, or any combination. It will sometimes go up or down in line with engine revs but with no real relevance to actual rpm (ex. 800rpm at 60mph).
When it first started this, turning the key off and then restarting would reset it to normal, only to have it go haywire a few minutes later. Now, shutting down only helps sometimes. I disconnected the battery yesterday to do a hard reset and when I restarted it worked great for about an hour, then reverted to the same problem. I have no driveability problems. The only other issue I've seen that could be related was one night my speedometer stopped working just as I was getting home. The next time I restarted the speedo worked fine and has ever since. This has been getting progressively worse for the past month or so.
Anyone have any ideas?
Thanks,
Dan
Thanks,
Dan
