Hello All, I just added a Video Interface to my 2010 Armada however when I plugged everything back in the monitor/radio/AC dash will not turn on..it’s all black. The ac is blowing but I cannot change it due to the whole dash unit is not working! Please help, any advice is much appreciated
47763
Here is my struggle..nothing is working?
Have you checked all the fuses? Not sure if there is a fuse specifically for that but worth a shot.
Hello All, I just added a Video Interface to my display monitor in my 2010 Armada however when I plugged everything back in the monitor/radio/AC dash will not turn on..it’s all black. The ac is blowing but I cannot change it due to the whole dash unit is not working! Please help, any advice is much appreciated
i have checked them but it’s worth a shot to double check. Really weird cause the ac is blowing but nothing is lighting up! Thanks for the reply
I was reading through the forum and fixed the blinking air bag light that started after I plugged everything back in! So that was super cool!
hello look I already have the same problem with my armada and I would like to know you found a solution
Thank you
