1 - 3 of 3 Posts
Hey guys,
I have most of my audio pulled (head unit, amp, etc.) I am hooking up another amp to drive my speakers and I have re-installed the factory head unit. Which wire is the factory "remote" wire to turn an amp on?
I bought a line output converter to take the factory signal out into the amp. I just need to get this last wire hooked up to make the amp turn on when I turn the key, and all will be well. Anyone know?
Try using the amp turn on wire in the stock system. Its voltage is only about 5.5 volts, but it has worked for others doing this. It is the Green/White wire circled in the attached drawing.
Thanks so much! I assume this is coming off the deck?
Gonna go check it out- I appreciate it!
1 - 3 of 3 Posts
