scr38 said:If you have everything switched properly and the air isn't cold then there is a problem with your unit. The Armada A/C works very well. I have my A/C on 90% of the time here in South Texas, and have never had a problem cooling in 105+ temps.
Sounds like you hit the Auto button but the AC wasn't on, just fan. Auto does not automatically put the AC on. Moving the temp down doesn't do this either. On my LE with dual climate control and NAV you need to engage this manually by pushing AC on one of the buttons until it lights up on the display.NorCalJay said:Same here - no cold AC.
The temp was around 75 outside & the AC was on 60 running all day at full blast but it was cooler to put the windows down. I tried both fresh & recycled air.
What's the deal? Sounds like I'll have it checked when I also bring it in for the "judders".
Jay (05 LE w/navtech)
Being the original poster of this issue I wanted to give an update. I was confused by all the posts indicating an "auto" button. I have an LE without the NAV system. All that is available is to ensure that the AC amber light is illuminated in the center of the dial and to adjust the blower. I took it into the dealer and they agreed that it was only blowing mildly cold. It seems that the compressor shuts on and off instead of staying on. They charged the AC with some dye to check for leaks, they are having me bring it back in when my Center roof console TSB arrives. I will post an update when I hear from them after the TSB is installed.92TripleBlack said:Sounds like you hit the Auto button but the AC wasn't on, just fan. Auto does not automatically put the AC on. Moving the temp down doesn't do this either. On my LE with dual climate control and NAV you need to engage this manually by pushing AC on one of the buttons until it lights up on the display.![]()
