I've fixed two major seat squeeks and here is how I did it.
The first squeek can be described as two crikets getting it on when there is no passenger in the seat. It's almost a constant squeek. To fix this one I removed the seat and put sound dampening material on the floor to act as a gasket between the seat and floor. It's been a couple of months since I did this and it hasn't come back. I used a material called Cascade but dynomat or something similliar that will not rub through easy would work.
The second squeek was when a passenger over about 150 lbs sat in the seat. It was more of a creak than squeek. I complained about this almost every trip to the dealer and their fix was to lubricate. Never did anything but make a mess. Well this morning I did some dective work and found these two bolts that weren't tight. I tightened them down snug and wala no more creak!
The photo below shows the inside bolt there is another on the door side too. This is the electric seat so I don't know if the manual ones have these bolts too. Anyway thought I'd share.
