301 - 320 of 322 Posts
Call dealer and they will charge $140.00 :eek: and it will take about two hours to diagnose. I wish there was a way i can diagnose, any tips?
Just came back from the dealer and they say is the spiral cable, code B1049, after discount of 100, i will end up paying about $440.00 plus tax. that is not a bad price, i am going to shop around and see if i can get cheaper somewhere else.
Question, It has probably already been addressed in prior pages but, if the light is reset and stays off, does that mean that the airbag system is functioning properly? or by resetting the light using the method described in this thread, does that just disable the light and the problem still exists in the system? OBD shows no codes. Thanks Tad
Valid question. I doubt the system could be reset if there was an active fault present, so I’m going to say that it is functional if the light is out.
I’m more concerned about the airbags themselves, being about 14 years old in my car now.
Just got back from a 2500 mile road trip to Canada and back, and didn’t have to reset the system once!
Just returned from a trip from Central Ca through Nevada, Idaho,Washington, and Oregon. A vintage wheat harvest in Eastern WA great fun.The light came on for the first time ever the morning we left, I did the reset that morning and it has not turned on since. Mine is an 06 110K miles Thanks Tad
I ended up taking it to the dealer. Mine its a 08 and little things here and there are starting to brake. It is old man, you can either do it, there are some youtube videos, it is time consuming and you have to be careful, or just pay, i think i pay about 200 something. This reset thing that everyone keeps talking about works maybe for a few hours, then it goes back blinkin. Old cars what can i say.
Since some of you guys here are new owners I thought I'd save you a trip to the dealer once you start modifing your armada's. I'm not sure what set's it off (other than pulling things apart) but at some point you will likely end up with a flashing airbag sensor light. Here is how to reset it yourself.
1. Turn the key from off to on.
2. Watch the airbag light closely. It will stay on for a few secs. and then as soon as it blinks off (the start of the flashing), turn the key off instantly.
3. Count to 5 (1 Mississippi, 2 Mississippi . . . .)
4. Repeat steps 1-3 two more times until you have done the cycle three times.
5. Now turn the key on and watch the light. It will start blinking in a different, slower manner. This is diagnostic mode. You can watch this for a little while, no hurry.
6. Now turn the key off again, Count to 5 like in step 3 again, and turn back on. If the procedure worked, the airbag light will not be flashing.
So I have done this procedure and it works but the light seems to come back on awhile later. Any idea's to why it would come back on?
Thank you so much for posting this. It worked! I will definitely be back to this site
I tried this twice. The light would go off, then after about 5 mins of driving it would come back on. Not sure what to try next.
Hi,
I have been searching google for awhile trying to figure things out. I have a 2008 nissan armada. I have had the air bag light blinking for about a year. At first it would reset, that no longer works. I do have the occasional VDC/brake/slip lights come on, they go away when car is shut off. One thing I did notice is the passenger airbag light is lit up and off when started but then goes off. My daughter was in the passenger seat the other day and it was lit up and off until she moved, light went off. I'm looking for advice. I really dread bringing it to the dealership. I do have a mechanic, I use. Would you bring it to the dealership, since they should be able to pin-point it? If you have an opinion, thanks in advance.
If you've tried the reset procedure and that no longer works then something is wrong. Likely a new clockspring assembly. That solved my same issue.
I replaced my clock spring assembly and followed the YouTube videos shared. It can be a DIY, just be very careful and mark each cable removal. After the new one is installed, you will have to bring it to a shop that has a code reader and have the error reset. The reset calls for the straightness of the steering wheel angle sensor. If you know the steering wheel is straight, the tech should just reset for a small fee or just tip em. The clock spring assembly was an updated part # most probably because of a defective manufacturing process.
Damn good advice, worked like a charm.
I'm reading thru this thread and noticing some folks are still having issues with their airbag light still blinking, even after a rest is done. I'm one of those folks. First things is to check for codes. In my case it's registering that I have a fault on the Front L/H belt pre-tensioner. This is the driver's seat belt harness. A replacement harness costs over $350 at Nissan. The other option is to send the harness out for repair @ $65. But first I need to make sure that the harness is actually bad or a faulty wiring.
I just recently bought.. and received this tool Bypass Simulate SRS Airbag Emulator Simulator Resistor -Diagnostic Tool- a simulator to troubleshoot your SRS system. Plug this tool in the connector of the said faulty device... and if the air bag light goes away then the device is bad and needs repair or replacement. If the air bag light continue to blink then. Check for more codes and or you have a bad wiring some where. Start chasing Gremlins...LOL
