It's not that simple. The light switches do not controll the lights directly. The switches control low voltage/current signals into the computer in the BCM. The BCM then turns on/off relays to control the lights. The stock fog light switch and related wiring will not handle the necessary power, even if you could rewire it. If you want to control the fog lights to turn on/ off in a different manner than stock you will have to do wiring/switching independent of the stock fog light switch. This can be done by adding a additional switch/relay and wiring to control the fogs directly or in conjuction with the park lights, low beams (as stock) or hi beams. It's just a matter of what you want.
