2008 Armada SE (good car until now) makes loud grinding noise at slow speeds as if the 4-wheel drive is trying to engage. At 70 mph, it makes a "rubbing/grunting" sound, especially noticeable when veering slightly to the left. Have you had this problem? Is it safe to drive?
Are you sure the noise is coming from the front differential? From what you describe, this almost sounds as though you need new front brake pads.
Does the noise go away when taking a curve either left or right? I have a similar noise that looks like will be a driver side wheel bearing.
