Administrator
what year are you referring to?
second gen armada:
2017+
2nd gen qx had the radar cutout in the lower bumper grille up until 2017 or when it changed to the qx80 if memory serves. i assume you're asking about armada.
second gen armada:
2017+
2017 Nissan Armada, Patrol, same as on photo you sheared
Protector plastic is obstruction? Should I cut it?
Vehicle registration plate Car Vehicle Grille Automotive lighting
But I got error message: front radar obstruction, what will happen if I cut it out and open radar screen
Administrator
if you are getting that error, it may mean you have an issue with the actual sensor. it could be a fault in the wiring or /an the actual unit itself. as seen in the photo, the radar is setup from the factory the way it is.
