1 - 7 of 7 Posts
I sometimes have this problem, but I can wait a minute and try it and it works. I can't explain it.
The automatic up/down feature of the front windows is based on something like a circuit breaker that stops the motor when a certain amount of resistance is met. This "breaker" is also tripped sometimes when the window first starts moving. Try starting the window up without pulling/pushing the switch past the auto-detent (the slight click you feel when it goes to auto up or auto down) - then push/pull it all the way. Should work fine.
If it ever does stall on you, wait a second then try again. The system should reset itself almost instantaneously.
Armadaof1 said:
Going into the dealer for a couple other issues (rear window growling on the way up/booming in cabin/brake warp), I'll add this to the list.
I've got the same rear window "growling" noise up or down. It sounds like there rocks stuck in there or something. Dealer told me he can't hear anything. What can I do???
1 - 7 of 7 Posts
