Fuses
1933 Views 7 Replies 4 Participants Last post by  marctronixx
have you guys seen the fuses they use in our trucks??? they are smaller than the mini fuses... i looked everywhere for them but i cant find them at pep boys,strauss,autozone.... maybe only form the stealer oppps i mean dealer! :)
fiddlyD
1 - 8 of 8 Posts
I found them at Walmart. They came in an assortment pack of about 5 of each different size. I think it was around $18.00.
Ken
Ken
I went and checked, and they are Buss mini ATM fuses. There are 5, 10, 15, 20, 25 and 30 amp sizes, about 10 each, along with a nifty fuse puller and checker. When I bought them, I pulled one from the Armada and compared them, they are the same.
Ken
Ken
Good info, thanks :)
hmmm there might be a differece in my QX are these the fuses that you have??
http://www.motorhomesandmore.com/mh_store/findsku.cfm/sku=3273
if those are the one mine are different ....the legas are shorted on mine and the plastic casing is a little bit different.
fiddlyD
fiddlyD
Maybe so...The package I have is labeled just as on the web site. To be sure, I just did a double check. I replaced the 15 amp fuse (panel by the glove box) labeled "Interior Light" with one out of the package. Pulled the fuse the light went out, replaced with new fuse, and the light came back on. Also just by looking at them, the have identical leg length.
Ken
then the QX must have different fuses....
fiddlyD
guys, is wally world the only place that carries these tiny fuses the armadas use? dealer is the last place ill go for just some fuses but before i go to wally world and waste my time, id rather go to a automotive store first. thanks in advance for any replies...
1 - 8 of 8 Posts
