1 - 8 of 8 Posts
Hello! Recently need to replace the rear ride height sensor in our ‘17 SL because back end was sagging big time.
$900 later, rear suspension looks like it’s still sagging a bit. The gap between rear tires and fender is roughly 3.75 inches whereas the gap between front tires and fender is roughly 5.25 inches with no significant cargo in the rear.
Can someone who owns a ‘17 or newer take a few moments to measure so I can see if that is normal? Can’t get a callback from the dealer who performed ride height sensor repair. Shocker.
2017 Nissan Armada Platinum
It's suppose to be like this to make the truck look level from factory.
If you raise it any higher you will have a rake towards the front. And like others have said, it's really easy to do.
1 - 8 of 8 Posts
