I am wanting to install a DVD system in the back for my duaghter and need some help deciding which brand....this is mostly kids DVD's so I do not need anything high end....I want to keep under $500. So I need two monitors and a DVD player. I want the DVD player in center consol...can I power this with the cig lighter or where would the best place to tap into for the monitors and DVD player.
1. Has to be wireless headsets.
2. What brand monitors and what is the largest size to fit.
3. Would I need in-line amp.
4. Signal amp needed since I have two LCD's to increase pic quality?
I was looking at this dvd player
http://www.mp3playerstore.com/stuff_you_need/dvd/FD-7TV.htm
And these Monitors
http://www.mp3playerstore.com/stuff_you_need/special/IN-600A.htm
So what else would I need to make this work?
I may also decide on overhead like this.
http://www.millionbuy.com/snymv7101ds.html
Thanks for any input
2004 NISSAN TITAN SE CC...NO NAV OR DVD
I couldn't get your links to work.
For the DVD I recommend Blaupunkt ME3. You should be able to get it for around $150. If you check the link in my signature I have a how-to on wiring into the factory head unit so that the rear controls will work for wireless.
Monitors, the best suggestion is to make sure it is TFT and has a good viewing angle. I have a blaupunkt in my overhead but it has been discontinued. Clarion is a good brand but they have some cheap stuff out there too so make sure you are getting what you think you are.
I was also looking at that DVD player, but I do not want to wire into any of the stock radio...I just them to listen with headsets..I don't want to listen to cartoons..LOL I fixed the links....sorry
You already have a transmitter you just need headphones, only the radio and CD go there...if you have factory dvd then that to of course. If you wire into the headunit like I did you will get the dvd audio to go there as well for aftermarket. I have links to headphones that work as well as how to do the wiring for a dvd linked in my signature
