The heated seat switch has a small line at the bottom and a large line at the top, low heat - high heat. Tonight I turned the seat on. The same small line at the bottom lights for the low and high setting. Is this correct? I thought the small line at the bottom would light for low and the large line at the top would light for high.
Thanks,
Stephen :confused:
'05, LE, Nav, DVD
Thanks,
Stephen :confused:
'05, LE, Nav, DVD
Mine is the same way.
Mine also. Its differnent on the G35 with the lights varying per setting. Maybe that is why the QX is $7k more? :D ;)
Thats the way it is
Mine lights the same way. Dont let the light fool you, go by the line. When you turn it up to high, the seats heat up pretty hot (at least enough for when its cold in Ca!!!)
I checked mine this morning, if you look closely you will notice that the lines on the switch don't even light up, the light is actually just above the small line. You will never notice in the dark, I just assumed that it was the lower line that had the light in it.
