1 - 1 of 1 Posts
Long story short, I had to fix a broken bin and now need to re-install into the overhead console (mine has a sunroof, if that makes a difference) of my '09. I broke the thing once and am a bit shy about trying to squeeze it in between the console pins. Which way does the coil spring go on? I don't see any obvious ways to tell. Are there any photos that might help? I understand that the spring goes on the left side - that's opposite of the side with the gear - right? Thanks a million for any help you can provide.
1 - 1 of 1 Posts
