New to this towing also...
Hey all, :hi:
I have been searching through the forum and reading the towing threads.
I have a 2004 Silver SE Armada, RWD (not 4x4) WITHOUT the big tow pkg.
I have since installed a class III hitch from Curt MFG (
http://www.curtmfg.com/classes.html) rated at 10,000 WD/ 6000 WC (I got a good deal, and need the extra $$$ for my other toys! Therefore, I didn't go w/ the OEM hitch.)
I am then looking to purchase a dual motorcycle carrier (Weight 121 lbs) from VersaHaul (
http://www.motorcycle-carriers.net/motorcycle_carriers_versa_haul.html) to carry two dirtbikes with a combined weight (wet) of 335lbs. Total tongue weight would then be 456lbs....
VersaHaul recommends no more than 322 lbs on a standard Nissan SE Armada hitch...based upon the fact that the load is extended 2 feet beyond the hitch and this distance will increase the stress upon the tongue. They also (in the FAQs) state that a load above this 322lbs on their carrier may bottom out the shocks of the SUV (a 2000 Tahoe was the test mule) and shift enough weight rearward to make for dangerous driving. Air Shocks are also recommended.
So my questions are; Does anyone have any experience w/ carrying a motorcycle on their Armada (without the Big Tow pkg) using the hitch? If not, has anyone w/out load-leveling shocks carried or towed anything that placed this amount of force upon their tongue (450-600 lbs) and did the vehicle become unstable and unsafe? Should I be concerned or can the hitch take the stress (600lb WC capability according to the hitch manufacturer.)
Any and all advise/experience is appreciated.
