1 - 11 of 11 Posts
How should I check the air shock absorver to see if they are working or not? I replaced a damaged one. Please suggestions.
Trinidad
Trinidad - are you talking about the rear leveling system? I would think the best way would be to put a load in the back of your truck. Then start the engine and see whether the compressor starts up and lifts the back up to its normal height.
Air Shocks Absorver
Yes, I am talking about the rear leveling system. I see. do you know how heavy should it be in order to see it work?
If you have a couple of people handy, have them sit in the back seat. A couple of hundred pounds should do it.
Air Shocks Absorver
I will try it this afternoon, Thank you kinly.
Yup ... get your a few heavy friends, pop the lift gate and have them seat at the back of your truck. Turn the ignition switch to on (without starting the engine) and you should notice the air pump will start to work. The noise of the pump is noticable.
Discussion Starter · #7 ·
Air Shocks absorver
Thank you much clear. I can wait to finished work and go home and do this.
Discussion Starter · #8 ·
Air Shocks
I tried and it didn't work, I have my wife, my 3 kids and myself about 700 pounds total and nothing happened. What should I do next? Suggestions please.
Suspension
Don't know if it will help, but if I drive my front wheels up, say a steep driveway and leave the rear wheels on the level (rear of vehicle is lower than front) my compressor turns on if I park it like that for a few minutes.
Discussion Starter · #10 ·
Air Shocks
Thank you, I will try it tomorrow.
Air Shocks
Start the engine and pump should start in about 30 seconds. If weight is inside vehicle might not be enough to weigh down rear. It works when I hook up my 6700 lb camper.
1 - 11 of 11 Posts
