In line level amp, something like this should work.
http://www.discountcarstereo.com/detail.aspx?ID=317
I ordered my second one from this site. A MUCH better price.PISHICO said:Thanks man just what i needed , ordering the part next weeek :udaman:
^^ tru dat, I use to use my iPod through the AUX, but now it's wayyy louderPISHICO said:Uce the Dvd a/v imputs as an option they have good volume.
When I plug my portable DVD into the aux on my bose system on my Armada 04 LE it will blow the doors off. I have no problem whatsoever... :awesome:PISHICO said:how to increase volume out of the AUX on dash ,I transfered my Sirius radio in to my mada hooked into the aux but the volume doesnt go as high compare to regular radio or cd , the Satelite radio doesnt have a volume ????? what to do ??/?
Jorge
Where do you get a GOOD cable to play your ipod through AUX jack?brysig228 said:is this low volume only apply on 2004-05 model armada? cuz my aux on my 06 has same volume when i play my ipod and the radio or cd.
Just got in today. Question for those that have it, where did you splice the connection into? Also, where did you guys end up mounting it?llajumpvid said:I ordered my second one from this site. A MUCH better price.
http://audioetc1.com/product_info.php/manufacturers_id/404/products_id/213857
I spliced the "out" of the amp in behind the dash jack and have the box installed under the passenger seat. It's there only because all my other connections are there so I kept everything together. You can easily install it behind the dash and either run a set of rca's out to where you want to plug into or install it in line with the dash jack and plug your audio source in there.abstrakt51 said:Just got in today. Question for those that have it, where did you splice the connection into? Also, where did you guys end up mounting it?
Thanks,
Thanks for your reply. May seem like a dumb question, but which wires did you splice for the power and ground?llajumpvid said:I spliced the "out" of the amp in behind the dash jack and have the box installed under the passenger seat. It's there only because all my other connections are there so I kept everything together. You can easily install it behind the dash and either run a set of rca's out to where you want to plug into or install it in line with the dash jack and plug your audio source in there.
I cant get ANY sound out of mine! What the steps involved?PISHICO said:Uce the Dvd a/v imputs as an option they have good volume.
I don't have the factory but I believe you need to hold the rear A/V button on the dash down for 1.5 seconds to activate the dvd over the cabin speakers. Then activate AUX on the DVD, not the dash but on the DVD player. I suspect there is a button for AUX on the dvd remote...perhaps on the player itself. The AUX button on the dash is not connected to the dvd it is only for the dash aux jack.Chris03HD said:I cant get ANY sound out of mine! What the steps involved?
ipod cord with rca's > rca's to audio inputs on oem dvd player > hit aux button on dash > hit power on oem dvd player > still no sound!
what am i missing here?
TIA!
Same here. It works in my '06!brysig228 said:is this low volume only apply on 2004-05 model armada? cuz my aux on my 06 has same volume when i play my ipod and the radio or cd.
I have an '06 as well, how are you hooking yours up, in-dash AUX input, or oem dvd player rca connection?BlakSpyda said:Same here. It works in my '06!
Aux input!Chris03HD said:I have an '06 as well, how are you hooking yours up, in-dash AUX input, or oem dvd player rca connection?
I have every option but XM on my '06 LE, so yes i also have the Bose. The audio input isn't "cutting it" going thru the dvd player, so I'll just have to try the simple cable from the ipod to aux on the dash next......92TripleBlack said:I have an Aux input on my '05 also. However, I don't know if the base radio comes with one. I have the BOSE system.
