1 - 10 of 10 Posts
SHIFT_Moderator
The instructions that come with the PRG Mini-lift are very helpful for the front but there's a couple of Gotcha's to note and no Instructions for the Rear so hopefully we can build this thread to fill in the Gaps.
Here are the PRG Instructions for download: http://performancelifts.com/installation/prg/PRGLKINST.pdf
For the Front:
Disconnecting the anti-sway bar end links was the toughest part. I had to take mine to a shop to have them use some industrial thread breaker with a huge breaker bar to loosen them then I drove home with them loose and did the rest by myself.
You can pickup PB Blaster, a 1/2" Breaker Bar for $25, and a Husky a 1/2" MM Hex Socket Set for like another $12 from Home Depot. You'll likely need it to break the Anti-Sway Bar loose, those 12-point or 24-point Socket Bits do not work, they'll round off the bolt heads.
Gotcha #1: Make sure to tie the Spindle in place with a Bungee Cord, Wire Coat Hanger, or something. If the spindle drops too low, the seal in your knuckle joint will break and you'll leak fluid. If this happens, you should be able to push the boot back together to reseal then have your fluids checked.
Gotcha #2: Make sure that all of the bolts are CENTERED in the holes when attaching the Spacer to the Strut. This affects with the Bolt alignment when reinstalling the Strut. If you cannot get the Bolts to all line up, loosen/reattach the spacer to get it better aligned
Gotcha #3: SPIN the Strut to reverse rotate it 180° when reinstalling. This is so the bolts will line up because the spacer reversed the Bolt Pattern on top.
For the Rear:
Remove your wheel, disconnect your Brake line from the Clips and if you have Load Leveling Suspension, disconnect the Lower Control Arm Bolt shown in this Pic.
Use a Hydraulic Jack to hold the Lower Spring Bucket and remove the Bolt to allow it to drop for Spring removal. Don't worry about it dropping too far, the spring action in the bushings will hold it up.
Follow the pics in this post to install the spacer:
http://www.clubarmada.com/forums/showthread.php?t=1497
Put it back together.
For Height Leveling Suspension, you may want to adjust the Sensor's Control Arm shown in the Pic above before reattaching. 1-2 counter-clockwise turns to lengthen it should be plenty for now and give it a day or two of driving to settle before changing again.
Gotcha #4: When reattaching the Lower Control Arm Bolt, make sure that the Sensor's Arm is in a HORIZONTAL postion like shown above, NOT vertical.
Rear Alignment can be a real bear to tackle.
Hopefully this will help future PRG installers. ;)
Boy that is a great job, you would have saved me a lot of time and worry over what I had done wrong. When the gear oil was leaking I was freaking out, I lucked out when I happened to push it back together. The only other thing that really gave me fits was what bolts to loosen on the sway bar os that I could actually get the strut back in once I had put the spacer on it, and how to lift it so it would spring back in place once I was done. I still don't know how I figured it out. And to someone like me who had never done anything like this before it was very nerve racking, I could have learned an expensive lesson on this vehicle, thank goodness for my neighbor and this forum. I had my alignment done on both the front and the back, but I am not sure if it is as good as yours, can I copy the receipt from the tire store and email it over to you? If so you can tell me how good a job they really did. Once again great job.
Thanks for the how to Pops. Your gotcha #4 was my situation. After reading this I corrected the problem and extended the sensors 2 turns. I'm now level front to rear.
Thanks for the info.
Bill
Hey guys; in need of help. Installed the rear 1.5" spacers with ease. The front was proving to be difficult. I couldn't get the upper ball joint to pop out of the steering knuckle.
Went at it with a hammer and pry bar. Am I just being too tender? I've seen videos where these things just pop off with a couple good whacks with a hammer.
Going to buy some PB blaster and a big sledge and trying again. Any tips would be great.
Aloha,
I will be tackling the install on some Rancho Spacers that go on the top of the springs in the rear. I am using this thread for help. The plan is to jack up the truck, remove tire, sit the truck on jack stands, compress spring using spring compressor (rented from auto parts store), remove brake lines and the bolt for the bucket with jack under the bucket, lower the bucket with jack, insert spacer and spring, raise the bucket, and bolt on bucket. Do I need to do a wheel alignment after this instillation? I was thinking I did not since I will not touch any of the wheel alignment bolts on the rear end. Any help will be appreciated. I am always humble with how little I know about mechanics but have been educating myself through friendly brother at CA.
Mahalo!
SHIFT_Moderator
Discussion Starter · #6 ·
First of all, do NOT combine spacers!!! You will never get it aligned with 2 sets of spacers, you're gonna be lucky to get aligned correctly with just one set.. Second, assuming you're using only one set of spacers, put them on the bottom, there's no reason they need to be on top. Third, YES you need an alignment anytime more than 1/4" of ride height is changed.
Thanks for the advice Bob. I am within perfect alignment specs as far as my current prg spacer installed. I understand your reservations with stacked spacers but I got to try. I have a 9 inch sub frame drob 2 inch prg spacer and HD springs but need 1 or 2 more inches in the back. The second spacer comes in today. After installation I will get an alignment and let CA know how it goes. Big mahalo to you. You give great advice and appreciate your insight on our trucks.
Can I put a set of 1.5" spacers on top of the front Bilstein 5100s?? I was thinking this way to avoid a rough/stiff ride with the 5100s at max lift setting I can put them on stock or next notch therefore attaining a 2.5 inch level sitting with a better ride. Or, should I just ditch the front spacers and max out the 5100s?
I asked about the 1.5" spacer because I took the Mada into the shop to put the 5100/rear spacer kit, and a full alignment. Afterwards, upon picking it up, my mechanic said there was a space between the strut bolt and the strut itself. He asked me if there is a bushing set that needs to go on the strut as to stop the play? Any help would be appreciated!!
1 - 10 of 10 Posts
