Status
Not open for further replies.
1 - 1 of 1 Posts
There is a easy way to get to the headlight bulbs to replace them.
1. First, remember to not touch the glass on the bulbs. Doing so may cause early failure of the bulbs. I use clean white cotton gloves when installing the bulbs.
2. Turn the steering wheel all the way to one side.
3. Look in the fender well at the plastic liner. Directly behind the headlight you will find a Phillips screw. This screw is in a recess in the fender liner. Remove this one screw.
4. The fender liner can now be easily pulled back to get access to the bulbs.
5. Disconnect the wiring plug from the bulb.
6. The bulb can now be rotated to remove.
7. Reverse the procedure to install the new bulb.
1 - 1 of 1 Posts
Status
