21 - 38 of 38 Posts
Cool… post some pics of your truck
very nice right up & responses. looking to do this as well very very soon. sooo if i understand right then i just order the new shocks (struts?) & re-use the springs from the original factory shocks? i have replaced struts/shocks before but they came with everything new, did not re-use anything... just want to make sure that i am uinderstanding it all? LOL!!!
THANKS!
THANKS!
Yes you can reuse your existing springs. They don't fatigue that fast under normal use and if your ride hight is still okay you are good. The strut packages I have seen that include the spring are not as good as stock springs (this seems to be consensus from what I have read here).
THANKS!
Yeah. Our fronts are coil overs and you can take the spring and the strut out together as a unit and then use a spring compressor to separate those two. After which you can either swap out the strut or the spring or do both.
Yes, most coil overs available out there are garbage for the Armada. You might as well burn your money, but Radflow coill overs for the front are a completely different story. I believe ntrddragn described them as smooth as butter. You can get them from PRG/Greg.
Pretty much any front coil-over for a Titan will work for the Armada. It all depends on what your needs/wants are... stock height? couple inch lift (couple options on how to achieve)? looking to go bigger than a couple inches in near future?
If you are looking to maintain stock height then the Bilstien HDs are one of your best bangs for your buck buys. You can also combine with PRG front and rear pucks to gain a couples of lift.
Another best bang for buck is the bilstein 5100s (adjustable) and may be combined with rear pucks for a couple inches of lift (IMHO PRG makes best quality pucks, both front and rear).
Greg/PRG knows Titans inside and out and may be able to offer you some more options of a complete front coil-over swap if you do not want to mess around, or pay someone to mess around, with a spring compressor.
Tools: Power tool if you have them. The 3 bolt on top of the struts are 14mm and the big one on the bottom is 3/4 (thats what i have to use for my power tool)
:D
I could be wrong, but i'm pretty sure I used a 19mm wrench for that bolt.
LIFTING QX56 or ARMADA
Im thinking of lifting my 2004 QX56 2-4 inches! Can anyone help with the most economical and right way to go?
Check out PRG mini lift... or do 5100s (on top perch) with Raybestos/Napa/moog HD rear springs and 2 inch rear pucks/spacers. I'd suggest PRG rear pucks.
This.
Not only will you achieve the height you're aiming for, the ride will improve just as much from the Bilsteins and HD springs. But lets not forget the most important thing... getting the truck aligned correctly after installing said parts.
This.
Ditto about the alignment!!
I just replaced my Front Shocks and Springs, car seems to be Higher in front now... Will the rear adjust soon? (2008)
Don't know if you need to wait for the new springs to settle to match the factory spring height. I just change my mada's front struts with bilstein 5100 set to the lowest setting and re-used the factory springs. It is all good now, same height and handles better. Has an appointment for alignment tomorrow.
my install info:
Thanks ntrddragn for your input on this thread.
Thanks Pops for your addition as well here - http://www.clubarmada.com/forums/showthread.php?t=8988
I used info from pops thread and this is what i did to get mine done:
Three top bolts are 14mm:
From there, i think removed the sway bar at the end link connection and the bottom bolt:
I flat black spray painted the rotors using high temp paint.....hate looking at rusty hats...so i hand scuffed them down a bit, wiped them really good and then sprayed them.
Rotors painted:
The shock just came right out with little to no effort, lots of room and easy to do.
I had the entire front of the armada on jack stands and the rear chocked at the tires.
Was a easy job really. front took me about 30 minutes total to get them off. on the way to work that day i stopped by a local shop and they swapped the springs to the bilstein shocks for $30 bucks cash.
BIG HINT! - Make sure to take a silver sharpie or a paint marker with you and mark the bolt and spring perch orientation. this is crucial!
I marked mine and one side was 100 percent perfect but the other side was a hair off and took some persuasion.
next day installling them back on took at most an hour because before installing the bilstiens back on i changed out all the alignment bolts with the moog camber bolts.
to do that i put a jack under the lower control arm and simply supported the lower control arm minus the shock installed and took one bolt out at a time. very very easy.
oem bolts are 19mm nuts paired with 22mm head on the bolt side.
When reinstalling i put the head side of the moog bolts facing each other - i did this because alignment techs wont be having to push one way, then switch to the next bolt and push the other way. with the head of the bolt on the aft side of the lower arm on the fwd side, this helps a bit.
The entire front minus the driving to the shop time, took about 1.5 total. I think what really made everything very quick is a few things, 1. I have done this all before on my titan, and 2. i had all the tools i needed.
Tools used:
Long handle wrenchs - make the job easier.
breaker bars - have small one with ratcheting feature.
electric impact gun
impact extenstion - 6 inch
deep and short sockets.
PB blasted everything nut and bolt head location the night before.
Job went very very smooth up front.
Rear I slapped in a 1.5 inch prg lift spacer in the coil bucket under the factory spring, paired with airrite red airbags for towing. also painted rear hats on rotors too.
The rear install was easy as well minus my drivers side toe bolt issue at alignment shop, Discussed here - http://www.clubarmada.com/forums/showthread.php?t=49034
Hope this helps others as this thread helped me.
-J
I have the same issue. I put some aftermarket front struts with coils since my OEM coilover BROKE. Now the truck sits higher (I'd say a couple inches higher) in the front.
Is there a remedy for that? I checked the "how to" section but could not find any solution.
I either need to lift the rear ( I have the autoleveing airshocks there) or replace them with a standard set of springs and struts to match the height in the front.
Any suggestions? Did anybody have the same issue? How did you resolve it?
Thank you!
Tagging this thread for my QX.
Any difference between these...
...and the 5100
I'm happy to spend the extra $40 or whatever for the 5100s, but I'm not concerned about lifting it or anything. Rear still has the air and I tow with it.
21 - 38 of 38 Posts
