Hope you don't mind a little cutting
Hi, we have a Thule 1800 that works great. Lo and behold though, getting ready to leave for Whistler and put it on for the first time and found the same problem. A couple hours and couple beers later though and all ready to go. Very straightforward fix.
The latches (4 of them) that hold the box to the cross bars slide in a slot. Basically, make the slot longer and the latches adjust farther.
Here is what I did:
1) Drill out four rivets holding sheetmetal guide piece for each sliding latch.
2) Mark slot approximately 4" longer. Drill 3/8" hole at end (nice rounded end)
3) Cut slot with fine tooth sabre saw (plastic is EZ to cut)
4) Drill 4 new holes, rivet with 3/16" dia. alum rivets (gun and rivets $20 at Lowes)
5) Rivet sheet metal covers and latches back on (make sure you point the latch right way)
6) Do the other 3 corners the same way. Cover extra slot with black duct tape if you are in a hurry to go skiing or put some extra sheet material (plastic or...) to cover if you really want to, it is not necessary.
Takes 5 minutes to put on or take off of Armada by myself. :clever:
Hope this helps. The Thule 1800 is also nice because it opens from either side. Also, I can fit into my garage (8' tall door) with it on top (but not your typical 6' - 9" or 10" parking structure, ouch! Almost went there when it was on the Pathfinder.
