It's been a while since I've posted, usually because I try to only post positive things about the Armada. Well, I've found something recently that just took my breath away - and I'm mad as a hornet about it. RUST.
There are tiny rust spots popping up all over my Armada. I did plan to get it undercoated but haven't had the time - but the rust is appearing in spots that would NOT be undercoated anyway. So far I've noticed rust spots under my rear window glass (facing aft on the back door), inside the passenger door frame around the window, around the NISSAN emblem on the tailgate, and on the drivers side pillar next to the windshield.
When I bought my Armada, I noticed a flaw in the paint on the pillar. I own a company that does aircraft paint, and this looks like (if I had seen this same flaw on an airplane) corrosion beneath the paint surface. I pointed it out to the dealer, and they said if it gets worse to bring it back. Let's just say at this point I'm glad they have record of it!
My question now is - what should I do? If I send the WIFE up there with it, she'll rip heads off. I tend to be a bit nicer in these situations, but what can the dealer possibly do? From my experience, I would say that it looks like the entire vehicle either got wet or was exposed to something in the paint process that began this corrosion / rusting beneath the surface. Again, it has NOTHING to do with the lack of undercoating (the undercarraige, ironically, is not showing any signs of rust at this point).
I still believe Nissan makes quality vehicles. I think that my Armada was just exposed to something that is causing this - but the problem could be severe. What will the dealer do? What should I ask for? A strip, prime and paint? A new vehicle all together??? Mine's only got 12,000 miles on it!
Any help is appreciated! Thanks!
Drew
EDIT - I'll post some pictures of the offending spots ASAP!
Drew
