If your thinking of installing an amp, I found a factory drilled hole on the passenger side. Great place to run the power cored. The wire is a 4 gauge.
thanks for the info. i had my amp installed and they run it on the driver side. when i decide to install the 2nd amp it'll go on that hole.SHOCKWAVE said:If your thinking of installing an amp, I found a factory drilled hole on the passenger side. Great place to run the power cored. The wire is a 4 gauge.
Makes sense. Probably a little electromagnetic interference!llajumpvid said:It's the firewall on the inside, there is a rubber plug that goes in the hole. What it's for I don't know other than to provide a hole for just such a thing as Shockwave is doing.
I ran a power wire through this same hole and it may of been coincidence but my remote range dropped to where I had to be standing next to the vehicle to unlock the doors. I pulled the wire out and the range returned to normal. The antennea is right above that hole so I'm guessing there was some interference.
Bklynromeo said:i love messing with ppl when they are parallel parking behind me from my gym window ill open the power lift when they get closer lol and they think ok someone is going put something in or out...then ill close it and then they go to yell at the jerk in the driver seat but its empty MUAH HA HA!
hey i get bored between sets
:schla24:
My truck is a '04 So I don't know if all Armada have this pre-drilled hole. On the passenger side remove the carpet & the black rubber. There should be a black plug that leads to the engine bayThe_Flood said:Where does the wire come out through on the engine side? I'm trying to run a wire through this hole for an amp but can't see it coming through on the other side.
