May b interested in lowerng the tank a bit. Does anyone know if therse a kit for it. TIA
So what do you consider a SUV like the ARMADA? But honestly i believe it's your ride.....do what you like with it!!!! I'm considering lowering my ARMADA too but most likely keep it stock height and just get some 22's with 305/ 45/ 22 tires on them.bluenoser said:To quote our fealess and most prolific poster...: cars are for lowering, trucks are for raising" ..good luck
these springs has been on backorder for the last yearbigboikoa said:there is a drop kit for the armada its at http://www.drivewire.com/performanceparts/intrax/nissanarmadaloweringsprings.html
True, but the reduced drag would be negligable. As for cornering, even lowered, it would handle like a pig. Good tires would do more than lowering for cornering improvement. Lots of the body roll isn't actually in the suspension but in our junky Conti-tires, and the roll hurts the handling more than the center of gravity. Look at an EVO. High center of gravity but it can handle as well as a Lambo due to the lack of body roll. Sure it will help, but again, its just trying to turn something into something it isn't, like putting a 4x4 raised suspension on a corvette. Sure you could, but why?andy said:Technically, by lowering, if you were to put the armada in a windtunnel and measure Cd, lowering the armada would reduce drag, as well as, increase cornering ability by lowering center of gravity.
Check out Baja vehicles, lots of travel but not raised up.
ockevin said:The Intrax springs are on ebay.
Just one pair? Do you mean 4 springs?bigboikoa said:I just picked up a pair and there was no problem. All i need is for someone to install them. I post pis ASAP.
If you mean they look more like minivans, less rugged, and should be painted pink, then yes. Have fun at the window dressing sale.coleman said:Lowering the Armada a couple of inches would look very cool with right tire and wheel combo. As we all know lowered trucks look alot better than raised trucks.
Lowering isn't supposed to improve the ride. It will always degrade it. Lowering is meant to lower the center of gravity to help improve handling. However, most people that lower their ride do it for looks, not performance. And most cars are lowered all they should be for roads. Lowering a car further really makes it a track vehicle as rough roads will make it bounce too much wrecking handling and possibly you. Also, the ride becomes substantially worsened and many people don't do a proper wheel alignment after lowering, which gives the car that squashed look, again hurts ride, and promotes poor tire wear.Matrix said:Wouldnt it also make the ride very bouncy. I'm tired of that bouncy ride. I've have lots of lowered rides and can't find a decent kit that keeps the ride smooth as factory. Better of course with some Bilsteins and fresh tires.
A lot of good points here.. I couldn't see lowering an Armada other than for the purposes of making it a show vehicle. I lowered my Mustang for a combination of looks and performance (well, primarily for looks92TripleBlack said:Lowering isn't supposed to improve the ride. It will always degrade it. Lowering is meant to lower the center of gravity to help improve handling. However, most people that lower their ride do it for looks, not performance. And most cars are lowered all they should be for roads. Lowering a car further really makes it a track vehicle as rough roads will make it bounce too much wrecking handling and possibly you. Also, the ride becomes substantially worsened and many people don't do a proper wheel alignment after lowering, which gives the car that squashed look, again hurts ride, and promotes poor tire wear.
If you want to improve the "bouncy" ride, get firmer shocks and better tires. This will dramatically dampen the bounce and firm things up. It will also improve handling more than lowering will. Though lowering helps handling, the amount of improvement is slight compared to good tires and shocks.
Remember, lowering:
Hurts ride quality
Promotes fast tire wear
Lowers resale dramatically
makes you a target for law enforcement
hurts off road performance
hurts towing
marginally may or may not improve any handling
costs bucks you'll never see again. (Figure costs twice as much as the actual cost of the kit to compensate for the lost resale value)
Lotta negatives to achieve a "look" that a majority of the population finds comical and undesireable. Similar to a 12" skyjacker with 46" tire look. Mild lifts that are useful off road are one thing. Extremes are another.
Lower trucks are OK for ones designed to be lowered from the factory for safety to compensate for supped up powerplants like such as the lightning, SRT series, Cayenne, etc. but most are just regular SUVs/Trucks that someone slapped a kit on and didn't properly integrate the entire suspension.
I'd say think before you dump your cash. I'd rather get a killer system I could put in my next vehicle, better rims and tires, performance parts, etc. than a dopey lift kit.
