Jacking Point/Rear Diff
scr38 said:
The jacking points are on the frame rails. Look in Section 6 in your owner's manual. I would not use a floor jack under the differential. It is an aluminum housing; also the mounting brackets for it are not designed to carry the load of the rear of the vehicle.
SCR38, you may want to take a closer look at the rear diff. It is not aluminum it is steel with an aluminum cover
The pinions and yolk are incased in solid steel. The key is to keep the floor jack off the 1/2 in lip. I have been lifting my Subaru’s and All Road for years. The diff can certainly carry the load, it is attached in several places directly to the frame. The torque the frame points see from off roading, towing or even general driving is far greater than what lifting would do.
If I had to lift just one side I would lift from the frame. I like to cross rotate my tires and use 4 jack stands.
