Status
Not open for further replies.
Leak, is this the oil cooler?
15K views 5 replies 4 participants last post by  jining
I'm not sure what that is. It seems things have changed a bit from my 2008. On my model, the oil cooler was what the oil filter screwed onto. Occasionally a seal would go bad on the cooler that mounted to the engine block itself and it is fairly easy to replace.
It may be something very similar here, they just moved the oil cooler to a separate unit and it's possible that seal has gone bad (or maybe the bolts just need to be tightened a bit.
Save
Status
