The Tech Package does show the individual tire pressures, but doesn't tell you what tire is which. If you have one low, then you still need to check all four to see which one it is. I've thought about messing around by pumping up one tire, then driving around until the system registers the pressure, and noting what position was for what tire, repeating until I had all four, but I've been too lazy.kthrash said:This feature is nice but it would be so much better if it was like my Jeep Grand Cherokee was where it would tell you in the overhead display each individual tire pressure so you would acutally know which one was low instead of having to check all 4. Plus I used to monitor the rear pressure while towing to make sure the rear tires were not getting too hot.
On a side note I think the Tech Package does allow for this on the DVD NAV Screen.
