1 - 11 of 11 Posts
2017 Armada Platinum
I've been trying to pull trans temp using both Torque Pro and OBD Fusion (with the Nissan add-on), and have been unable to with both. In Torque, I'm able to get the engine coolant and oil temps, but nothing from the trans. In Fusion, I get a temp of 0 for both the trans and engine oil temps. I've tried using two different ELM327 based dongles (the Tonwon that a few others have recommenced, and an old generic one that I've had for years).
It would also be nice to get the oil pressures for both the engine and trans, as I see them come up in Fusion, but read as -40 mPa, and do not change.
Is there a different OBDII dongle (that's not crazy expensive) that I should try?
If there is another tread that covers this, please point me to it, as I wasn't able to find it searching on my own.
2019 Armada SL
I've spent a good deal of time on this subject. I've been using OBD Link SX and in Torque Pro there is 'Trans Temp (Method 1)' that gives me a number. To see that sensor, I had to go to the Settings > OBD2 Adapter Settings and make sure 'Hide unsupported sensors' is not checked.
However, it is always identical to the coolant temp. Apparently the transmission cooler is in the radiator, so they do have the same temperature. At least that is what the consensus has been.
So, even if you're not seeing the option for the trans temp, you already know it as well as anyone else, because it is the coolant temp.
QUESTION: Do second GEN Armadas have Transmission Temp gauges? If NOT then the quote above may be true. But on FIRST GENS... the rate of temp rise between the COOLANT and TRANSMISSON are different, so they use different temp sensors.
I use a LAUNCH Creader CPR129X 4 systems code reader. It's NOT the best. But it allows me to read ENGINE and TCM data. RESET CODES and view/record real-time vehicle DATA while driving. Transmission temp on 1st Gens (Normal) is about 168F and it rises gradually as I drive . COST $225.
2019 Armada SL
2nd Gen's do not have a trans temp gauge.
Discussion Starter · #8 ·
Yes. Under the conditions i mentioned with that pid under network g. Max temp I have seen was 208 towing 5k over 12,000 ft.....
I don't have Network "G" only "A", and then separate modules. Trying to connect to anything be sides Network A gives a connection error.
Font Darkness Event Number Screenshot
Light Gadget Red Line Font
Here is my working dash and my connection. Did you buy the extended pid pack?
Font Darkness Screenshot Number Terrestrial plant
Mine is a 2014, so here is what I needed to add to et trans temp.
Discussion Starter · #10 ·
Yes, I did purchase the enhanced Nissan PID's for my 2017 model year
I tried rescaning for PID's again today, and still came up with the same number of PID's, and same networks. Does anyone have any suggestions?
Looking at getting a OBDLink LX it's $60 on the Amazon has anyone used this on a Gen2?
1 - 11 of 11 Posts
