Magnaflow is very good. I don't know if just adding a better flowing muffler will help or not. Your flow will only be as good as the most restrictive point. This could be intake, heads, headers, cats, exhaust, or mufflers. If any of the others are more restrictive, you will not realize anything but a noise change.sinnerFA said:For those who skipped getting the whole cat-back system and went with just a muffler upgrade, what muffler did you choose to go with?
I just want to get a better flowing muffler...
TiA :itsfriday
Thanks for the info!scr38 said:I don't think this is the best way to go. After you have bought the muffler and paid to have the modifications done to the stock system in order to use the muffler you will spend about as much as if you bought a cat back system and installed it yourself. The most restrictive part of the stock system is the Y pipe, where the two head pipes join. You will still have this restriction after you install the new muffler. Also the complete cat back systems are designed as a system, with all the parts working with each other. You won't get this with just a muffler replacement.
The cat back systems, such as the Gibson, are a bolt on unit; no cutting or welding needed. Everything fits well, all the bends are mandrel bent, and the installed system looks professional.
I think the best system for the Armada is the Gibson 3" single. It has a good sound and produces a performance increase in the lower RPM range, where it is the most usefull. If you search posts here and on ClubTitan you will find several posts about the Gibson system, including some dyno testing.
I have had the Gibson single installed for about 10,000 miles now. There is very little difference in sound at idle. It is a little louder with heavy acceleration, but it is a good sound, not raspy. The Gibson is louder at crusing speeds of 50-65, but at 70-75 it is about the same as stock. Above 75 you almost can't hear it.adjmcloon said:Hey scr,
I'm thinking about the Gibson..don't you have it installed? I'm worried about how much noisier it is- the stock system is just right volume-wise. I could probably stand it a bit louder, but definitely no 'drone'. If it truly produces additional torque in the low range that would be nice. The last system I had (Corsa) on my Tahoe 5.3 actually lost me low end- it was a single side exit with a dual tip.
Originally I was trying to just replace the stock muffler with a flowmaster 45 or 50, but I was just trying to figure out how people felt about just doing this... I was alos looking for the dimensions...casinojames said:Did I miss it or is nobody interested int eh Flowmaster option? I've heard some titans with 50's and it sounded pretty tough.
