Hey everyone, lurked a while, joined and bought a 2004 Armada with 114k mile on it for 3800. I bought it to tow a travel trailer - 7500lbs. Here are the known issues:
White/grey smoke on startup - smells like oil. No sweet smell. No oil/coolant leaks. No oil in coolant overflow.
Oil gauge pegged on high as soon as ignition is turned on, stays pegged on high when motor running.
Brakes need replaced.
What I ordered to fix the issues and do a DIY tuneup:
Valve covers, gaskets
PCV valves
Oil Pressure Switch
Oil Pump (just in case)
Oil - Pennzoil Platinum High Mileage Full Synthetic 5W-30 Motor Oil
Oil Filter - FRAM Ultra Synthetic
HD Gear Oil for front and rear - Lucas Oil HD 80W90
Transmission fluid, seal and filter - OEM Matic S
Brake pads and rotors - Callahan CDS02514 REAR Slotted 319.6mm D/S 6 Lug [2] Rotors + Ceramic Brake Pads, Detroit Axle - Pair (2) Front Drilled and Slotted Disc Brake Kit Rotors w/Ceramic Pads
Tekonsha Prodigy P2 Brake Control
Ignition Coils
MAF Sensor
Autolite Iridium XP Spark Plugs
Tires: Winterforce LTLT265 /70 R18 124R E1 BSW because I will be towing it to Mt Hood for snowboarding competitions all winter long.
What I have:
Equali-i-zer 10k lb Sway Control Hitch
What I am still researching:
Off season tires and rims
Cold air intake? Installed one on my WRX and made a difference.
After market anti-sway bar (Eibach)?
Upgrade suspension - especially the rear?
Any thoughts or ideas on what I may be missing?
Thanks everyone for all of your dedication to the scene!
Dj
PCV valves
Oil Pressure Switch
Ignition Coils
MAF Sensor
What I have:
Dj
