Attached are two photos showing my 0-60 and 1/4 times.
I have the Volant CAI, Gibson single cat back, Airaid TBS, throttle body heat bypassed and the timing advanced 2 degrees. Nothing major. Original wheels and tires. I use 87 octane fuel.drcookie said:scr38, what do you have under the hood? Still bone stock? That time is pretty impressive.
Hope he's doing a bit better than 18.888! My Mom's Sentra can do better than that!scr38 said:The added weight will slow you down, but it shouldn't be that much. I think that Armada has posted times similar to mine. (I searched and found his times_ 0-60 was 6.545 and 1/4 was 18.888)
Thanks for catching the typo! I have changed it in the post; the correct time is 14.888.Campfamily said:Hope he's doing a bit better than 18.888! My Mom's Sentra can do better than that!![]()
I figured that's what you meant.....but, couldn't resist.scr38 said:Thanks for catching the typo! I have changed it in the post; the correct time is 14.888.![]()
If you take the cover off the air box and remove the filter you will see a long snorkel tube inside the box running through the box out into the cold air hole in the left front fender.Tmation said:airbox internal tube mod
Whats that then, is it easy to do, do you have instructions?
Thinking of going for drop in K&N myself as standard airfilters cost $50 each here in sunny Saudi.
scr38, Which Gtech model you using to measure this?scr38 said:Attached are two photos showing my 0-60 and 1/4 times.
