Just a shot in the dark but, did you reset your oil change reminder?drcookie said:Folks,
I am not sure if any of you have experience this problem before. I did a search on the forum but came up nothing.
My 05 MADA LE w/Navi started to beep once precisely every 5 minutes. It appeared to start doing it this morning after I changed the oil. I dont' believe the oil change was the source of the problem. The wifey had the suv yesteday but she did not mention this problem. The noise seemed to be coming from somewhere below/behind the HU.
Everything is normal from the console. No check engine light, the tire pressure is normal (38-40 psi) the radio and Navi are operating.
I searched the manual but no luck.
Please help me troubleshoot this beep noise. Will engine code show anything since the engine light was not even on?
