my point is the charging system will not charge the battery up as you would expect. Primo added some extra bits that will further shed light on this.Thank you for the quick reply but, this happens regardless of if it is a short drive doing errands or a 3 hour drive.. no car or truck at this age should run like this, and none of my past cars have.. I shouldn't have to buy a spare battery, a trickle charge or a battery booster just to make sure I can make it home from where I am because the truck will not start. That is unacceptable on the part of Infiniti.
your car is likely not at fault, but that does not mean that you may not have an issue elsewhere. maybe you should spend the 80 bux to have nissan give it a once over.
you are right - you should not have to do those things, and you dont normally. i mean ive had my 2012 qx new since 2012 and ive never had a stall or any other issue with the battery. i DID use odyssey batteries and never looked back. the stock nissan battery is not robust for the sensors and computer network the car has and thet battery should be replaced soon.
again, there are thousands of these cars on the road and not everyone has issues that you and some others here describe. there could be some other issues that are not showing their head yet, so a diag of your car may be in order.
