I need to replace the light assembly in front of the sunroof. I removed the two screws but it's still secured. Is there another screw holding it in place?
Yes it's still snug after removing the two screws.thanks for the photos. i was under the impression you already removed it.. 🧐
i attached the exploded parts list of the roof and it only looks like 2 screws. perhaps there are some "push pin" style clips that are holding it up as toname suggests.. or maybe you just need a little more elbow grease..
is the console loose after you removed the 2 bolts? or does it still feel sung/tight against the roof?
How much did it cost you for that unit. I need to replace mine because the light switch is broken. Nissanpricedeal.com has it for $600+ ouch. Good luckYes it's still snug after removing the two screws.
That helps out a lot! thank you both!Yes it's still snug after removing the two screws.
