1 - 2 of 2 Posts
I can figure for the most part on how to set up the DVD/Monitor to intall. But...I can't figure out where the amp goes into this. I am running an all M&D system. Any advice would help. Thanks in advance.
If you are following my dvd instructions, you probably don't need an line level amp (PIE LD1 or similiar). Seems only the 04's had the weak inputs. If you need one though you will plug the DVD output into the input on the amp and the output from the amp goes to the HU.
1 - 2 of 2 Posts
