1 - 3 of 3 Posts
New Alikee low beam LED's. Synetics switchbacks DRL/signal lights. Yellow LED fogs
Tire Wheel Car Land vehicle Vehicle
Reactions: Rock_Lee
How hard was it to install the Halo's/led lighting?
Not that hard, lots of guides here on how to do it. You have to remove the front grill, and remove a couple of screws on the inner fender liner. Each headlight has 4 bolts holding it in place. Be careful of the "bumper filler" piece on the bottom of the headlight assembly, they can break easily. The headlights I chose connect directly to the factory harness. My Armada did not come with fog lights, but the wiring harness was there. Installing the new yellow fog lights was a matter of minutes. I used the stalk/switch from an 04 Maxima (eBay) which was plug and play and works perfectly.
1 - 3 of 3 Posts
