1 - 1 of 1 Posts
Vendor
Comfortable stepping in and out of the truck becomes the main concern of truck owners from the first days of owning it. Luckily, this can be easily solved by adding a pair of running boards, but not all of them are as good as PowerStep from AMP Research. They are designed to extend and retract automatically as you open and close your doors, which gives you and your passengers an easy-access stepping surface that boasts a weight capacity of almost 600 lbs.
AMP Research Running Boards feature marine-grade aluminum construction with stainless steel pivot pins for superior strength and durability with black textured finish and self-lubricating bushings offering maintenance-free weather-resistance. They come with integrated LED lighting, heavy-duty motors that lasts for years and has proven roadworthy in the toughest conditions.
You've probably seen them installed on other trucks, now it's a perfect moment to get a set for yourself! Purchase any AMP Research PowerStep, PowerStep XL or PowerStep XTreme and claim up to $150 Prepaid Visa Card. Don’t wait! This offer is valid from July 1 through September 30, 2017.
AMP Research™ | Power Side Steps, Running Boards, Bed Extenders - CARiD.com
Don't hesitate and contact me today for a quote or leave your inquiries below!
1 - 1 of 1 Posts
