1 - 1 of 1 Posts
Sun Performance is releasing their new line of compressors, the QuickAir X, which is due to release in April. These compressors will be of higher quality and faster than their previous QuickAir's and capable of running air tools. We currently have two models available and come in a hardmount or portable version:
QuickAir X 1500
- 12-Volt
- Permanent Magnetic Motor
- Amp Draw: 20 Amps
- Duty Cycle: 100% @ 100 PSI
- Max Working Pressure: 150 PSI
- Min. Ambient Temperature: -40 degrees F
- Max. Ambient Temperature: 160.6 degrees F
- Dimensions: 257L x 100W x 163H
- Net Weight: 7.72 lbs.
- Time to fill 2.5 Gallon Tank: 0-100 psi - 2 min 30 sec.
QuickAir X 2000
- 12-Volt
- Amp Draw: 22 Amps
- Max Working Pressure: 200 PSI
- Max. Ambient Temperature: 142.2 degrees F
- Dimensions: 288.5L x 100W x 163H
- Net Weight: 9.26 lbs.
- Time to fill 5 Gallon Tank: 0-200 psi - 11 min 15 sec.
PM for more information!
1 - 1 of 1 Posts
