I was just curious if other Armada owners follow the 15,000 mile maintenance intervals. I am about to hit 15,000 miles and the dealer wants $160.00 to do these things. Will I end up regretting not having these things done or do others just do it themselves. I feel like if I don't do it and something fails it will be held over my head by the dealership.
Oil change
top off fluids
check lamps horn and warning systems
tire pressure and wear
Adjust drive belts, hoses and clamps. (I thought the belt had a self adjusting pulley?)
Lubricate and inspect front suspension, steering and door hinges.
Rotate and balance tires
Clean and adjust brakes, and inspect brake lines
fuel system cleaning and fuel injector service
pressure test cooling system, heater hoses and upper and loser radiator hoses
inspect struts and shocks
replace air filter
inspect battery and service.
Oil change
top off fluids
replace air filter
