1 - 3 of 3 Posts
Here is my problem need help ? I have to feather the gas pedal for it to go to a max speed of about 55 it also sounds like it may be backfiring if I push the gas to hard .
when I try to go up a hill it will back down to nearly 20 miles an hour has no power ?
clogged cats?
bad petrol?
faulty plugs/coilpacks?
dirty AMF?
faulty o2 sensor(s)?
other engine issues.
evap purge valve?
what troubleshooting steps have you done to try and find the problem? did you pull any codes at the obd port?
when did this start? have you had the car long? what's the history and maintenance of the car?
Sounds like clogged cats to me.
1 - 3 of 3 Posts
