OEM DVD player and monitor
2082 Views 9 Replies 6 Participants Last post by  armoody
Hi, I just join in the club. I have a 2004 SE and I need help. Does anybody know if the SE come with the harness to hook up an OEM DVD player with OEM monitor? Because I'm planning on putting an used one on my truck and I just want to make sure before if it come pre wire for this.
1 - 10 of 10 Posts
I think there is a harness for the DVD connection under the center console, but I will check ;) , and welcome
llajumpvid installed a computer in his Mada, yoyu may want to check out his thread, I still don't know how to post it. but under interior Modification you find a picture of it ( Subject: stock DVD system question ) sorry, I hope that help, or some body help pleeeeeeeeeeease :eek:
ok, Now could somebody out there who is a computer literate tell me how to attach a thread ? and please english language not :comphead: :confused:
look at the header in the post window, there is the earth symbol. Click on that put in a name (optional) and paste in the link you want. Or just cntrl+c the address of the page you want and then just cntl+v it into your post
this is a test: respond if it worked please
http://www.clubarmada.com/forums/showthread.php?t=196&highlight=llajumpvid :)
link worked just fine. Good job.
thanks, finally :goteam:
Kudos to llajumpvid
I followed his detailed documentation and hooked up rca jacks last summer so that we can run our portable DVD player audio throught the DVD source in the Mada. Not as swank as built ins, but way cheaper and you can pull the DVD player out and use it in those condos and hotels that don't include a DVD player. Have an "adapter" so that the DVD doesn't slide around on the center consol.
Would like built in video, but they are competing with new furniture, skis, wakeboard tower,.... you get the picture.
I just need to motivate and hook in the line level amp. The level between wired and IR headphones created a disturbance in the passenger section, so I need more line input. (Eg even with the volume all the way up one was too low. Have two IR and one wired headphone set)
Picture is of the rca's in the center consol (Note they are located to the right - for those reading regularly you will recall placing to the left interferes with the shifter action)
See less See more
1 - 10 of 10 Posts
