License plate ones won't work, at least the one I bought didn't. Ther are made for mounting when there is something above the plate. I ended up cutting it out of the plate and mounting it in the blank on the rear hatch handle opposite of the rear window glass handle.andy said:Where does the OEM rear view camera go? I'm considering adding one on and I can't figure out a good place for it. I've seen license plate ones.
Anyone know if there are pictures on the web somewhere?
Did you have to run the wiring up through the headliner? Sounds painful. I assume 2 power wires and a video cable? Does the blank come off? or did you drill a hole in it while on hatch?llajumpvid said:License plate ones won't work, at least the one I bought didn't. Ther are made for mounting when there is something above the plate. I ended up cutting it out of the plate and mounting it in the blank on the rear hatch handle opposite of the rear window glass handle.
Here you go. I'll post some photo's of how my aftermarket looks tonight.manny0 said:Anyone posted pics of stock location of the cam. My dealer does not have this option on any of there armadas
The way I have mine is going through the avelectronic.com box. Don't know if there is a way to get it to work using something out of the 05' model.dmarmada04le said:Hello, I'm new to this forum, I own an 04 Armada LE with Nav system. Does anyone have info on how to wire up a camera to the system? Does it come on automatically when you put the Armada in reverse? Where can I purchse the camera?
Thank in advance for any info you might have.
