1 - 1 of 1 Posts
Many of what Nissan calls gaskets and what are commonly called crush washers for the drain bolts for driveline fluid changes can be found as OEM or aftermarket parts cheaper online. Below are the part numbers for those looking to do this service themselves.
front differential drain and fill both: no gasket instead use Permatex 56521 High Performance Thread Sealant (listed in service manual as the aftermarket cross reference part number)
transfer case drain and fill both: 11026-1CA0A
transmission drain (this is the drain bolt gasket not the pan gasket): 11025-JA00A (this is the same as the engine oil pan drain bolt gasket)
rear differential drain and fill both: 11026-4N200
Specified fluids can be found in the owner's manual.
1 - 1 of 1 Posts
