1 - 3 of 3 Posts
I'm almost to the install phase of putting a PC in the mada to compliment the navi/avelectronic box I already have and was looking for where I was going to put the misc switches/usb/firewire ports. I found the perfect place! I can't believe I hadn't thought of before.
There is that little swing out arm on the front of the center console in the little bin between the shifter and console to hold a large cup...if the bin is ever empty enough to put something in it.. If you swing out that arm there is a nice little cubby behind it that you could put a switch or two easily and be stealthy. The spot would be perfect to relocate a mini jack to and wire it into the AUX jack for those who use the AUX for a Ipod etc and not have wires running across the dash. Just thought I'd pass it along to others who may not of thought about this spot.
Hey, I noticed that your setup includes a wireless headphone system. How did you hook this up? What brand is the transmitter and how do you switch between sources? I want to set one up in my car that has 2 video sources and three screens. When a user, switches to a source in the car, I want the audio output on the headphones to reflect that switch. Any help would be appreciate as to what you used and where you bought your stuff. Thanks alot.
I'm using the built in factory IR transmitter...only one source at a time, sorry. There are multi channel trasmitters out there. Look for a RF one.
1 - 3 of 3 Posts
