Bought this off a person who intended to fix it up. Picked it up for $400.00.I believe it's a SE with 4wd.
I don't know much about these vehicles,pretty much owned Maxima's my whole life. Been on Maxima.org for 20 years.
Don't know the story ,it was just in a front end accident.
I almost have all the bad stuff off. Side rails are a little bent in. And power steering system is leaking and spraying fluid everywhere.
After taking oil cooler off(damaged in accident,or i thought it was)because it would't stop leaking. I had a ball bearing fall out. That's when i discovered the relief valve.I think the leak was just the gasket. So there's oil and power steering fluid everywhere.
I have some pictures, only had it for a month or so. I'll have to get better pictures.
I am buying parts now . I know about the radiator problem and the relief valve problem.
Anything you guys do to these vehicles, or the such, i should know about?
Like what radiator to buy? I heard the stillen one leaks after a couple years.
