Insulator Body Mounting. 2005-2015 Nissan Armada. 2004 Nissan Pathfinder Armada. Genuine Nissan Part Number: 92136-1FA0A.
www.ebay.com
Picked up two of these from eBay ,the front body mounts. And the things they bolt to are these two front things. I have removed these, and I am in the process of replacing with used ones. They are piece of the body they do not unbolt , spot welds must be taken out.
They were rusty where the mounts bolt on and the accident didn't help.
I have both engine mounts on , pictures soon.
The front crossmember, or as Nissan calls it crossmember 1. The one I cut off a Armada in the junkyard. I didn't notice , someone must have yanked something hard out, while using the drivers side tow hook. Because the Boss or mounting nut was ripped out. These suspension sway bar nuts, are used for many things on the Armadas. I bought a bunch of these for the third crossmember, but also to weld a new boss on the 1st . I had to rebuild the area, as you can imagine a nut being ripped through the member. I also tapped all the holes and reinforced the member, with welding.
Suspension Sway Bar Link Nut. Part Number(s): 54588-AD002, 54588AD00A. Suspension Stabilizer Bar Link Nut. Warranty Duration: 1 Year.
www.ebay.com
This is the drivers mount installed with new Bolts, this was much harder than passenger side. keep in mind i have the whole front of the truck off.
Also installed front body mounts and the body piece it bolts on. Welds are very sloppy, My welding helmet broke and i was welding with my hands over my eyes. I have one on order.
Well every thing is back in alignment and I test fitted everything on the front. I used part of the old front crossmember that I cut off to make plates, and did some welding. Very front member will be welded on after engine area work is done, it's much easier with it off. But everything fits, after the accident and the tow hooks on the front help with every thing lining back up. They were essential, to getting everything almost perfectly back, to stock dimensions. And last picture, the radiator support bolts all line up, this is how it's done in the factory everything part, check each other parts alignment for fit.
Next step ordering Exhaust and headers.
